Partes
No se requieren partes.
  1. Turn off power to laptop. Unplug charging cable from laptop.
    • Turn off power to laptop.
    • Unplug charging cable from laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap to prevent any electrical shock to the components. Shocks may damage the components.
  2. Carefully turn the laptop over. Switch each of the battery latches to the "unlocked" position.
    • Carefully turn the laptop over.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Remove the two 5.5mm screws that secure the base cover to the computer's base. Using the plastic opening tool, carefully pry open the base cover starting from the center. Lift the base cover upwards to remove and set it aside.
    • Remove the two 5.5mm screws that secure the base cover to the computer's base.
    • Using the plastic opening tool, carefully pry open the base cover starting from the center.
    • Lift the base cover upwards to remove and set it aside.
  4. Remove the 5.5mm screw that secures the optical-drive assembly to the computer base Using your fingertips, slide the optical-drive assembly out of the optical drive bay. Using your fingertips, slide the optical-drive assembly out of the optical drive bay.
    • Remove the 5.5mm screw that secures the optical-drive assembly to the computer base
    • Using your fingertips, slide the optical-drive assembly out of the optical drive bay.
  5. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  6. This step is only needed if replacing the optical drive. Remove the 2.5mm screw that secures the optical-drive bracket to the optical drive assembly. Remove the optical-drive bracket from the optical-drive assembly.
    • This step is only needed if replacing the optical drive.
    • Remove the 2.5mm screw that secures the optical-drive bracket to the optical drive assembly.
    • Remove the optical-drive bracket from the optical-drive assembly.
    • Carefully pull the optical-drive bezel and remove it from the optical drive.
  7. Remove the 2.5mm screw that secures the hard-drive assembly to the computer base. Using the pull tab, slide the hard-drive assembly to disconnect it from the system board. Lift the hard-drive assembly off the computer base
    • Remove the 2.5mm screw that secures the hard-drive assembly to the computer base.
    • Using the pull tab, slide the hard-drive assembly to disconnect it from the system board.
    • Lift the hard-drive assembly off the computer base
  8. Disconnect the antenna cables from the wireless card. Push the securing tab to release the wireless card. Slide the wireless card out of the wireless-card slot.
    • Disconnect the antenna cables from the wireless card.
    • Push the securing tab to release the wireless card.
    • Slide the wireless card out of the wireless-card slot.
  9. Turn the computer over and open the display as far as possible Using a plastic opening tool, release the tabs that secure the keyboard to the palm-rest assembly. Before turning over the keyboard, be careful not to pull the keyboard too far away as it could damage the connected ribbon cables.
    • Turn the computer over and open the display as far as possible
    • Using a plastic opening tool, release the tabs that secure the keyboard to the palm-rest assembly.
    • Before turning over the keyboard, be careful not to pull the keyboard too far away as it could damage the connected ribbon cables.
  10. Carefully turn the keyboard over and place it on the palm rest assembly.
    • Carefully turn the keyboard over and place it on the palm rest assembly.
    • Lift the latches and disconnect the keyboard cable and keyboard back-light cable from the system board.
    • Lift the keyboard along with the cables, off the palm-rest assembly and set it aside.
  11. Remove the (5) 5.5mm screws that secure the palm rest to the system board. Close the display and turn the computer over.
    • Remove the (5) 5.5mm screws that secure the palm rest to the system board.
    • Close the display and turn the computer over.
    • Remove the (10) 5.5mm screws that secure the palm rest to the computer base.
  12. Turn the computer over and open the display as far as possible. Lift the connector latches and disconnect the power-button board cable and the touch-pad cable from the system board. Using a plastic scribe, gently lift and release the tabs on the palm rest around the computer base including the backside.
    • Turn the computer over and open the display as far as possible.
    • Lift the connector latches and disconnect the power-button board cable and the touch-pad cable from the system board.
    • Using a plastic scribe, gently lift and release the tabs on the palm rest around the computer base including the backside.
    • Lift the palm rest away from the display assembly.
  13. Remove the 2.5mm screw that secures the optical-drive connector board to the computer base. Move wireless card wires covering the board away from the board. Slide the optical-drive connector board away from the computer base.
    • Remove the 2.5mm screw that secures the optical-drive connector board to the computer base.
    • Move wireless card wires covering the board away from the board.
    • Slide the optical-drive connector board away from the computer base.
    • Lift the optical-drive connector board away from the computer base.
Conclusión
Christopher Tran
Miembro Desde 13/02/18
1,140 Reputación
12 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 26
