Partes
No se requieren partes.
  1. Turn off power to laptop. Unplug charging cable from laptop.
    • Turn off power to laptop.
    • Unplug charging cable from laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap to prevent any electrical shock to the components. Shocks may damage the components.
  2. Carefully turn the laptop over. Switch each of the battery latches to the "unlocked" position.
    • Carefully turn the laptop over.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Turn the computer over and open the display as far as possible Using a plastic opening tool, release the tabs that secure the keyboard to the palm-rest assembly. Before turning over the keyboard, be careful not to pull the keyboard too far away as it could damage the connected ribbon cables.
    • Turn the computer over and open the display as far as possible
    • Using a plastic opening tool, release the tabs that secure the keyboard to the palm-rest assembly.
    • Before turning over the keyboard, be careful not to pull the keyboard too far away as it could damage the connected ribbon cables.
  5. Carefully turn the keyboard over and place it on the palm rest assembly.
    • Carefully turn the keyboard over and place it on the palm rest assembly.
    • Lift the latches and disconnect the keyboard cable and keyboard back-light cable from the system board.
    • Lift the keyboard along with the cables, off the palm-rest assembly and set it aside.
Conclusión
Christopher Tran
Miembro Desde 13/02/18
1,140 Reputación
12 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 3
Todo El Tiempo: 64
