Qué necesitas
Herramienta utilizada en este paso:Anti-Static Wrist Strap$7.95
Turn off power to the laptop.
Unplug the charging cable from the laptop.
Remove the two 5.5mm screws that secure the base cover to the computer's base.
Using the plastic opening tool, carefully pry open the base cover starting from the center.
Lift the base cover upwards to remove and set it aside.
Casi Terminas!
Conclusión
