Saltar al contenido principal
Dell Inspiron 17-5748 Speakers Replacement
Qué necesitas
  1. Dell Inspiron 17-5748 Speakers Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop upside down.
    • Locate the battery lock latches.
  2. Dell Inspiron 17-5748 Speakers Replacement: paso 2, imagen 1 de 1
    • Slide both lock latches to the unlocked position.
  3. Dell Inspiron 17-5748 Speakers Replacement: paso 3, imagen 1 de 1
    • Lift the battery up and out of the laptop battery socket.
  4. Dell Inspiron 17-5748 Speakers Replacement, Speakers: paso 4, imagen 1 de 3 Dell Inspiron 17-5748 Speakers Replacement, Speakers: paso 4, imagen 2 de 3 Dell Inspiron 17-5748 Speakers Replacement, Speakers: paso 4, imagen 3 de 3
    • Remove the 4.5 mm Phillips #0 screw holding the Optical Drive in place.
    • Slide the Optical Drive out of the device.
  5. Dell Inspiron 17-5748 Speakers Replacement: paso 5, imagen 1 de 2 Dell Inspiron 17-5748 Speakers Replacement: paso 5, imagen 2 de 2
    • Remove the two 4.5 mm Phillips #0 screws on the access panel door.
  6. Dell Inspiron 17-5748 Speakers Replacement: paso 6, imagen 1 de 2 Dell Inspiron 17-5748 Speakers Replacement: paso 6, imagen 2 de 2
    • Using a plastic opening tool, pry open the access panel, exposing the disk drive, RAM, and wireless module.
  7. Dell Inspiron 17-5748 Speakers Replacement: paso 7, imagen 1 de 3 Dell Inspiron 17-5748 Speakers Replacement: paso 7, imagen 2 de 3 Dell Inspiron 17-5748 Speakers Replacement: paso 7, imagen 3 de 3
    • Remove the 2.5 mm Phillips #0 screw securing the hard drive.
    • Slide the hard drive out using the pull tab.
    • Remove the hard drive from the device.
  8. Dell Inspiron 17-5748 Speakers Replacement: paso 8, imagen 1 de 1
    • Open the laptop and locate the keyboard.
  9. Dell Inspiron 17-5748 Speakers Replacement: paso 9, imagen 1 de 2 Dell Inspiron 17-5748 Speakers Replacement: paso 9, imagen 2 de 2
    • Locate the 5 keyboard tabs at the side of the keyboard closest to the screen.
    • Using a metal spudger, gently pry the keyboard tabs inwards until they loosened. You should hear a click.
  10. Dell Inspiron 17-5748 Speakers Replacement: paso 10, imagen 1 de 2 Dell Inspiron 17-5748 Speakers Replacement: paso 10, imagen 2 de 2
    • Do not remove the keyboard completely. The ribbon cable underneath, attaching it to the motherboard, must still be detached.
    • Lift the keyboard partially and flip it over.
  11. Dell Inspiron 17-5748 Speakers Replacement: paso 11, imagen 1 de 2 Dell Inspiron 17-5748 Speakers Replacement: paso 11, imagen 2 de 2
    • Detach the ribbon cable from the motherboard by tilting up the black clip, releasing the cable.
    • Gently detach the cable and the keyboard from the laptop.
  12. Dell Inspiron 17-5748 Speakers Replacement: paso 12, imagen 1 de 1
    • Remove the five 4.5 mm Phillips #0 screws found under the keyboard.
  13. Dell Inspiron 17-5748 Speakers Replacement: paso 13, imagen 1 de 3 Dell Inspiron 17-5748 Speakers Replacement: paso 13, imagen 2 de 3 Dell Inspiron 17-5748 Speakers Replacement: paso 13, imagen 3 de 3
    • Do not fully remove the palm rest until the ribbon cable underneath is detached.
    • Using a plastic opening tool, separate the plastic palm rest and partially lift the palm rest from the device.
    • Remove both ends of the ribbon cable. This can be done by flipping up the black tabs securing both ends.
    • Remove the palm rest from the device.
  14. Dell Inspiron 17-5748 Speakers Replacement: paso 14, imagen 1 de 3 Dell Inspiron 17-5748 Speakers Replacement: paso 14, imagen 2 de 3 Dell Inspiron 17-5748 Speakers Replacement: paso 14, imagen 3 de 3
    • Locate the first speaker.
    • Unplug the speaker cable.
  15. Dell Inspiron 17-5748 Speakers Replacement: paso 15, imagen 1 de 2 Dell Inspiron 17-5748 Speakers Replacement: paso 15, imagen 2 de 2
    • Lift the speaker from the corner.
    • Remove the speaker.
  16. Dell Inspiron 17-5748 Speakers Replacement: paso 16, imagen 1 de 2 Dell Inspiron 17-5748 Speakers Replacement: paso 16, imagen 2 de 2
    • Using the plastic opening tool, gently remove the second speaker.
Conclusión
Una persona más ha completado esta guía.
Bradley
Miembro Desde 02/12/18
235 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 539
