Saltar al contenido principal
Dell Inspiron 17-5748 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 17-5748 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop upside down.
    • Locate the battery lock latches.
  2. Dell Inspiron 17-5748 Keyboard Replacement: paso 2, imagen 1 de 1
    • Slide both lock latches to the unlocked position.
  3. Dell Inspiron 17-5748 Keyboard Replacement: paso 3, imagen 1 de 1
    • Lift the battery up and out of the laptop battery socket.
  4. Dell Inspiron 17-5748 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 1
    • Open the laptop and locate the keyboard.
  5. Dell Inspiron 17-5748 Keyboard Replacement: paso 5, imagen 1 de 2 Dell Inspiron 17-5748 Keyboard Replacement: paso 5, imagen 2 de 2
    • Locate the 5 keyboard tabs at the side of the keyboard closest to the screen.
    • Using a metal spudger, gently pry the keyboard tabs inwards until they loosened. You should hear a click.
  6. Dell Inspiron 17-5748 Keyboard Replacement: paso 6, imagen 1 de 2 Dell Inspiron 17-5748 Keyboard Replacement: paso 6, imagen 2 de 2
    • Do not remove the keyboard completely. The ribbon cable underneath, attaching it to the motherboard, must still be detached.
    • Lift the keyboard partially and flip it over.
  7. Dell Inspiron 17-5748 Keyboard Replacement: paso 7, imagen 1 de 2 Dell Inspiron 17-5748 Keyboard Replacement: paso 7, imagen 2 de 2
    • Detach the ribbon cable from the motherboard by tilting up the black clip, releasing the cable.
    • Gently detach the cable and the keyboard from the laptop.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 645
