Saltar al contenido principal
Dell Inspiron 17-3721 Optical Drive Replacement
Qué necesitas
  1. Dell Inspiron 17-3721 Optical Drive Replacement, Keyboard: paso 1, imagen 1 de 2 Dell Inspiron 17-3721 Optical Drive Replacement, Keyboard: paso 1, imagen 2 de 2
    • Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
    • After prying the tabs up, carefully pull the keyboard out of the laptop.
    • Use caution when prying the tabs up or lifting the keyboard up, as the plastic material and the strip on the keyboard can easily break.
  2. Dell Inspiron 17-3721 Optical Drive Replacement: paso 2, imagen 1 de 2 Dell Inspiron 17-3721 Optical Drive Replacement: paso 2, imagen 2 de 2
    • Once the keyboard is lifted, locate the release tab.
    • Using a plastic opening tool or your finger, lift the tab so that it opens .
    • Once the tab is open, the strip on the keyboard can be removed.
  3. Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: paso 3, imagen 1 de 3 Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: paso 3, imagen 2 de 3 Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: paso 3, imagen 3 de 3
    • Remove the four 6 mm PH1 Philips head screws under the keyboard.
    • Carefully pop off the cover using the plastic opening tools and your hands.
  4. Dell Inspiron 17-3721 Optical Drive Replacement: paso 4, imagen 1 de 3 Dell Inspiron 17-3721 Optical Drive Replacement: paso 4, imagen 2 de 3 Dell Inspiron 17-3721 Optical Drive Replacement: paso 4, imagen 3 de 3
    • Remove the 4 mm PH1 Philips head screw holding down the optical drive.
    • Use your hand to slide the drive out of the device.
Conclusión
Una persona más ha completado esta guía.
Kevin Prairie
Miembro Desde 03/20/18
445 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team S5-G3, Peak Spring 2018 Miembro de UMass Dartmouth, Team S5-G3, Peak Spring 2018
UMASSD-PEAK-S18S5G3
Miembros de 3
7 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 24
Todo El Tiempo: 364
