Saltar al contenido principal
Dell Inspiron 17-3721 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 17-3721 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 2 Dell Inspiron 17-3721 Keyboard Replacement, Keyboard: paso 1, imagen 2 de 2
    • Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
    • After prying the tabs up, carefully pull the keyboard out of the laptop.
    • Use caution when prying the tabs up or lifting the keyboard up, as the plastic material and the strip on the keyboard can easily break.
  2. Dell Inspiron 17-3721 Keyboard Replacement: paso 2, imagen 1 de 2 Dell Inspiron 17-3721 Keyboard Replacement: paso 2, imagen 2 de 2
    • Once the keyboard is lifted, locate the release tab.
    • Using a plastic opening tool or your finger, lift the tab so that it opens .
    • Once the tab is open, the strip on the keyboard can be removed.
Conclusión
Una persona más ha completado esta guía.
Kevin Prairie
Miembro Desde 03/20/18
445 Reputación
4 Guías creadas
Equipo
Un comentario
Wow that was easy! Thanks :D
Isaac Pettis - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 22
Todo El Tiempo: 470
