Saltar al contenido principal
Dell Inspiron 17-3721 CMOS Battery Replacement
Qué necesitas
  1. Dell Inspiron 17-3721 CMOS Battery Replacement, CMOS Battery: paso 1, imagen 1 de 3 Dell Inspiron 17-3721 CMOS Battery Replacement, CMOS Battery: paso 1, imagen 2 de 3 Dell Inspiron 17-3721 CMOS Battery Replacement, CMOS Battery: paso 1, imagen 3 de 3
    • Remove the two 6.5 mm PH1 Philips head screws on the back panel.
    • Lift up the small panel from the top, using the plastic opening tools if necessary.
  2. Dell Inspiron 17-3721 CMOS Battery Replacement: paso 2, imagen 1 de 2 Dell Inspiron 17-3721 CMOS Battery Replacement: paso 2, imagen 2 de 2
    • Remove the CMOS battery with the plastic opening tools.
    • Be careful while prying it open, the battery holder can break if you use too much force.
    • Do not use metal tools when touching anything that can have an electric charge.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 22
Ultimos 30 días: 39
Todo El Tiempo: 1,052
