Saltar al contenido principal
Dell Inspiron 17 N7010 BIOS Battery Replacement
Qué necesitas
  1. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove disc drive: paso 1, imagen 1 de 1
    • Remove the single Philips screw securing the disc drive.
    • Pull the disc drive out.
  2. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: paso 2, imagen 1 de 3 Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: paso 2, imagen 2 de 3 Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: paso 2, imagen 3 de 3
    • Remove the 22 M2.5x5 Philips screws securing the palmrest to the base.
    • Remove the seven remaining M2x2.5 screws securing the palmrest to the base.
    • Unscrew the two captive screws securing the RAM/HDD door to the base.
    • This must be done in order to access hidden screws under the hard drive.
    • Under the RAM/HDD door, unscrew the hard drive caddy. Remove the caddy.
    • Remove the three M2.5x5 screws from under where the hard drive was.
  3. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove keyboard: paso 3, imagen 1 de 1
    • Pop the four keyboard clips with a plastic spudger. As you do the first one, pry to get under the keyboard with your hand.
    • Remove the keyboard cable from the motherboard connector.
  4. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest: paso 4, imagen 1 de 2 Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest: paso 4, imagen 2 de 2
    • Remove the palmrest cables from the motherboard connectors.
    • Remove the seven M2.5x5 screws securing the palmrest to the base.
    • Lift the palmrest.
  5. Dell Inspiron 17 N7010 BIOS Battery Replacement, Replace the cell: paso 5, imagen 1 de 1
    • Use a plastic spudger to get under the CR2032 cell and pry it out carefully.
Conclusión
14 personas más completaron esta guía.
Joseph Sctbunio
Miembro Desde 09/23/17
7,416 Reputación
42 Guías creadas
7 comentarios
thanks for your help!!!
E P - Contestar
I’m happy that my guide helped you!
Joseph Sctbunio -
Lot of screws, wouldn’t even tried this without these instruction.
Thank you.
d223e
Don Endress - Contestar
Thanks for the instructions. Computer starts up great now.
jkleinjans - Contestar
doresc sa comand pentru Dell Inspiron 17 N7010 BIOS Baterie. 1 bucata. cum se procedeaza?
Florentin Manolea - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 23
Ultimos 30 días: 102
Todo El Tiempo: 18,145
