Saltar al contenido principal
Dell Inspiron 17 Laptop Battery Replacement
Qué necesitas
  1. Dell Inspiron 17 Laptop Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Before starting, make sure the laptop is powered off and disconnected from any power sources.
  2. Dell Inspiron 17 Laptop Battery Replacement: paso 2, imagen 1 de 1
    • Remove the Screws of the Laptop with help screwdriver.
    • There are 6 screws to remove. Make Sure to open the back of the laptop delicately.
  3. Dell Inspiron 17 Laptop Battery Replacement: paso 3, imagen 1 de 1
    • Carefully disconnect the old battery from the motherboard.
    • Gently remove the old battery from its housing by removing plug of battery.
  4. Dell Inspiron 17 Laptop Battery Replacement: paso 4, imagen 1 de 1
    • Insert the new battery into the housing.
    • Connect the new battery to the motherboard.
    • Securely reattach the battery back cover.
  5. Dell Inspiron 17 Laptop Battery Replacement: paso 5, imagen 1 de 1
    • Plug in the laptop and charge it to Full Capacity.
    • Power on the laptop and make sure it works with the new battery.
Conclusión
6 personas más completaron esta guía.
Anmol Desai
Miembro Desde 09/14/23
286 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 64
Ultimos 7 días: 183
Ultimos 30 días: 310
Todo El Tiempo: 3,344
