Saltar al contenido principal
Dell Inspiron 16-7620 RAM Replacement
Qué necesitas
  1. Dell Inspiron 16-7620 RAM Replacement, RAM: paso 1, imagen 1 de 3 Dell Inspiron 16-7620 RAM Replacement, RAM: paso 1, imagen 2 de 3 Dell Inspiron 16-7620 RAM Replacement, RAM: paso 1, imagen 3 de 3
    • Using a Phillips #00 screwdriver, fully unscrew all seven 5 mm screws circled in red.
    • Using the same screwdriver, unscrew the two 5 mm screws circled in orange until the back of the laptop begins to pop off.
    • Keep in mind should not be fully removed; they are captive screws.
    • Starting near the hinges of the laptop, use a jimmy to work around the laptop, carefully prying the back off.
  2. Dell Inspiron 16-7620 RAM Replacement: paso 2, imagen 1 de 3 Dell Inspiron 16-7620 RAM Replacement: paso 2, imagen 2 de 3 Dell Inspiron 16-7620 RAM Replacement: paso 2, imagen 3 de 3
    • Lift up the black covers outlined in red to reveal the RAM module(s).
    • Gently push the two metal arms outwards to release the RAM module.
    • The RAM should pop out of its socket when you release the second tab.
  3. Dell Inspiron 16-7620 RAM Replacement: paso 3, imagen 1 de 2 Dell Inspiron 16-7620 RAM Replacement: paso 3, imagen 2 de 2
    • Remove the RAM by sliding outwards.
Conclusión
Una persona más ha completado esta guía.
Lucian Chauvin
Miembro Desde 06/28/23
97 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 26
Todo El Tiempo: 242
