Saltar al contenido principal
Dell Inspiron 16 7610 Back Case Replacement
Qué necesitas
  1. Dell Inspiron 16 7610 Back Case Replacement, Back Case: paso 1, imagen 1 de 2 Dell Inspiron 16 7610 Back Case Replacement, Back Case: paso 1, imagen 2 de 2
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove four 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
    • Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity.
  2. Dell Inspiron 16 7610 Back Case Replacement: paso 2, imagen 1 de 1
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
Conclusión
Jerson Gomez
Miembro Desde 02/02/23
877 Reputación
3 Guías creadas
Equipo
Gateway, Team 1-3, Pee Spring 2023 Miembro de Gateway, Team 1-3, Pee Spring 2023
GCC-PEE-S23S1G3
4 Miembros
6 Guías creadas
Un comentario
Followed instructions. No clips broken but still cannot close the back cover. There’s a small gab in between the mouse and the cover when I close it.
Enos Nii Armah - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 20
Ultimos 30 días: 37
Todo El Tiempo: 780
