Saltar al contenido principal
Dell Inspiron 15R Webcam Replacement
Qué necesitas
  1. Dell Inspiron 15R Webcam Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the device over and locate the battery.
  2. Dell Inspiron 15R Webcam Replacement: paso 2, imagen 1 de 2 Dell Inspiron 15R Webcam Replacement: paso 2, imagen 2 de 2
    • Place thumbs on each latch and push outwards.
  3. Dell Inspiron 15R Webcam Replacement: paso 3, imagen 1 de 1
    • Push and slide the battery away from you.
  4. Dell Inspiron 15R Webcam Replacement, Keyboard: paso 4, imagen 1 de 3 Dell Inspiron 15R Webcam Replacement, Keyboard: paso 4, imagen 2 de 3 Dell Inspiron 15R Webcam Replacement, Keyboard: paso 4, imagen 3 de 3
    • Locate the RAM compartment and the screw on the right hand side. Remove the cover.
  5. Dell Inspiron 15R Webcam Replacement: paso 5, imagen 1 de 2 Dell Inspiron 15R Webcam Replacement: paso 5, imagen 2 de 2
    • Locate and remove the 2.5 mm x 5 mm screw on the upper right hand side of the compartment.
  6. Dell Inspiron 15R Webcam Replacement: paso 6, imagen 1 de 1
    • Turn the device around and open it up.
  7. Dell Inspiron 15R Webcam Replacement: paso 7, imagen 1 de 2 Dell Inspiron 15R Webcam Replacement: paso 7, imagen 2 de 2
    • Using your index finger, push down on the F1 and F7 keys.
  8. Dell Inspiron 15R Webcam Replacement: paso 8, imagen 1 de 2 Dell Inspiron 15R Webcam Replacement: paso 8, imagen 2 de 2
    • Using your index finger, push down on the x icon and Home keys.
  9. Dell Inspiron 15R Webcam Replacement: paso 9, imagen 1 de 3 Dell Inspiron 15R Webcam Replacement: paso 9, imagen 2 de 3 Dell Inspiron 15R Webcam Replacement: paso 9, imagen 3 de 3
    • Locate the keyboard lining (between the black and silver).
    • Place your spudger between the keyboard lining behind the F1 and F7 keys and pull up.
  10. Dell Inspiron 15R Webcam Replacement: paso 10, imagen 1 de 2 Dell Inspiron 15R Webcam Replacement: paso 10, imagen 2 de 2
    • Place your spudger between the keyboard lining behind the x icon and Home keys and pull up.
  11. Dell Inspiron 15R Webcam Replacement: paso 11, imagen 1 de 2 Dell Inspiron 15R Webcam Replacement: paso 11, imagen 2 de 2
    • Carefully pull and turn the keyboard over.
  12. Dell Inspiron 15R Webcam Replacement: paso 12, imagen 1 de 2 Dell Inspiron 15R Webcam Replacement: paso 12, imagen 2 de 2
    • Lift the black lever.
  13. Dell Inspiron 15R Webcam Replacement: paso 13, imagen 1 de 2 Dell Inspiron 15R Webcam Replacement: paso 13, imagen 2 de 2
    • Remove the keyboard cable
  14. Dell Inspiron 15R Webcam Replacement, Hard Drive: paso 14, imagen 1 de 2 Dell Inspiron 15R Webcam Replacement, Hard Drive: paso 14, imagen 2 de 2
    • Turn laptop over and remove the bottom four screw covers outlined in red.
    • Then remove the three base screws.
  15. Dell Inspiron 15R Webcam Replacement: paso 15, imagen 1 de 2 Dell Inspiron 15R Webcam Replacement: paso 15, imagen 2 de 2
    • Turn laptop over and open it. Locate and remove the five palm rest screws.
  16. Dell Inspiron 15R Webcam Replacement: paso 16, imagen 1 de 3 Dell Inspiron 15R Webcam Replacement: paso 16, imagen 2 de 3 Dell Inspiron 15R Webcam Replacement: paso 16, imagen 3 de 3
    • Locate the palm rest cables. Lift the black levers and unplug the blue cables.
  17. Dell Inspiron 15R Webcam Replacement: paso 17, imagen 1 de 2 Dell Inspiron 15R Webcam Replacement: paso 17, imagen 2 de 2
    • Lift the palm rest until it snaps off.
  18. Dell Inspiron 15R Webcam Replacement: paso 18, imagen 1 de 2 Dell Inspiron 15R Webcam Replacement: paso 18, imagen 2 de 2
    • Close cover and turn laptop over. Locate and remove the four hard drive screws.
  19. Dell Inspiron 15R Webcam Replacement: paso 19, imagen 1 de 1
  20. Dell Inspiron 15R Webcam Replacement: paso 20, imagen 1 de 3 Dell Inspiron 15R Webcam Replacement: paso 20, imagen 2 de 3 Dell Inspiron 15R Webcam Replacement: paso 20, imagen 3 de 3
    • Lift and remove the hard drive.
  21. Dell Inspiron 15R Webcam Replacement: paso 21, imagen 1 de 1
    • Remove the hard drive connector.
  22. Dell Inspiron 15R Webcam Replacement, Screen: paso 22, imagen 1 de 2 Dell Inspiron 15R Webcam Replacement, Screen: paso 22, imagen 2 de 2
    • Locate and remove the bottom hinge screws.
  23. Dell Inspiron 15R Webcam Replacement: paso 23, imagen 1 de 3 Dell Inspiron 15R Webcam Replacement: paso 23, imagen 2 de 3 Dell Inspiron 15R Webcam Replacement: paso 23, imagen 3 de 3
    • Turn laptop over and open it. Locate and unplug the LCD Cable.
  24. Dell Inspiron 15R Webcam Replacement: paso 24, imagen 1 de 3 Dell Inspiron 15R Webcam Replacement: paso 24, imagen 2 de 3 Dell Inspiron 15R Webcam Replacement: paso 24, imagen 3 de 3
    • Unplug the black and white wires on the wireless antenna.
  25. Dell Inspiron 15R Webcam Replacement: paso 25, imagen 1 de 3 Dell Inspiron 15R Webcam Replacement: paso 25, imagen 2 de 3 Dell Inspiron 15R Webcam Replacement: paso 25, imagen 3 de 3
    • Remove the two hinge screws on both the left and right hand side.
  26. Dell Inspiron 15R Webcam Replacement: paso 26, imagen 1 de 1
    • Remove the screen.
  27. Dell Inspiron 15R Webcam Replacement, Webcam: paso 27, imagen 1 de 1
    • Unsnap and lift the display bezel around the edges and remove it.
  28. Dell Inspiron 15R Webcam Replacement: paso 28, imagen 1 de 2 Dell Inspiron 15R Webcam Replacement: paso 28, imagen 2 de 2
    • Locate and remove the eight LCD screws outlined in red.
  29. Dell Inspiron 15R Webcam Replacement: paso 29, imagen 1 de 1
    • Carefully unplug the camera cable.
  30. Dell Inspiron 15R Webcam Replacement: paso 30, imagen 1 de 1
    • Lift and remove the LCD screen from the backing.
  31. Dell Inspiron 15R Webcam Replacement: paso 31, imagen 1 de 2 Dell Inspiron 15R Webcam Replacement: paso 31, imagen 2 de 2
    • Locate and remove the webcam.
Conclusión
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 782
