• Slide the latches over and remove the battery.
    • Loosen the 2 screws and remove the access door.
    • Separate the clips and remove the memory.
    • Remove the 2 screws and slide the hard drive to the left & lift it out of the laptop.
    • Remove the 12 bottom screws
  1. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    • Turn the laptop over and open it up. Press the keyboard latches in and loosen the keyboard.
    • Carefully turn the keyboard over. Unplug the keyboard cable. Remove the keyboard.
    • Unplug the cables. Remove the 7 top palmrest screws. Remove the palmrest.
    • Unplug the display cables. Remove the 3 left & right hinge screws
    • Remove the LCD display assembly.
    • Unplug the fan cables.
    • Remove the 1 screw holding the motherboard. Remove the motherboard
    • Remove the 4 heatsink screws. Remove the heatsink.
Conclusión
Una persona más ha completado esta guía.
Luke Legg
Miembro Desde 27/09/17
1,490 Reputación
7 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 44
