Introducción
If the Wi-Fi connection to your computer doesn’t hold, you may be experiencing a malfunction of your Wi-Fi module. This guide will show you how to remove the Wi-Fi module for the Dell Inspiron 15R 5537.
The Wi-Fi module is located underneath the keyboard and is connected by two antenna cables. A malfunctioning Wi-Fi module can result in connection issues to the wireless network. This issue doesn’t completely disable your laptop, however, it does cause an inconvenience. A quick fix can be to use ethernet to connect to Wi-Fi or purchase an external Wi-Fi adapter.
It is important to make sure that the antenna cables are properly connected to your Wi-Fi module and that the wires aren’t frayed.
Before beginning this guide, make sure your laptop is powered off and disconnected from any external power source.
Qué necesitas
Turn the laptop over so that the keyboard is facing up.
Use an opening tool to pry the keyboard from the base of the laptop.
Once the top of the keyboard is released, slide the keyboard upwards.
