Saltar al contenido principal
Introducción
In this guide, we will be showing you how to remove and replace the Memory Module.
Partes
No se especificaron partes.
  1. WARNING:  Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Loosen the captive screw that secures the memory-module cover to the computer base.
  2. Using your fingertips, lift the memory-module cover out of the slots on the computer base.
    • Using your fingertips, lift the memory-module cover out of the slots on the computer base.
  3. Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Remove the memory module from the memory-module connector.
    • Remove the memory module from the memory-module connector.
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  6. Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
  7. Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
    • Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
  8. Tighten the captive screw that secures the memory-module cover to the computer base.
    • Tighten the captive screw that secures the memory-module cover to the computer base.
Linea de Meta
Terrence15
Miembro Desde 18/12/17
70,815 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 27
