Saltar al contenido principal
Dell Inspiron 1564 RAM Replacement
Qué necesitas
  1. Dell Inspiron 1564 RAM Replacement, RAM: paso 1, imagen 1 de 2 Dell Inspiron 1564 RAM Replacement, RAM: paso 1, imagen 2 de 2
    • Locate the battery latch on the bottom of the computer and slide it to the right.
    • While holding the battery latch, pull the battery away from the device.
  2. Dell Inspiron 1564 RAM Replacement: paso 2, imagen 1 de 1
    • With the Phillips #0 screwdriver, loosen the three screws from the cover behind the battery latch.
  3. Dell Inspiron 1564 RAM Replacement: paso 3, imagen 1 de 3 Dell Inspiron 1564 RAM Replacement: paso 3, imagen 2 de 3 Dell Inspiron 1564 RAM Replacement: paso 3, imagen 3 de 3
    • Locate the RAM on the bottom of the computer.
    • Remove the RAM by gently pulling back the small clips along the side of the RAM, and lifting the RAM upwards so the RAM is now angled.
    • Pull the RAM away from the device.
    • Repeat the actions above for the second stick of RAM.
    • When reinstalling the RAM, put it back in at an angle in the socket, and make sure the RAM is audiblely clicked into place.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 982
