Saltar al contenido principal
Dell Inspiron 1564 Laptop Battery Replacement
Qué necesitas
  1. Dell Inspiron 1564 Laptop Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Place the laptop on a flat surface and open the cover.
    • Unplug the power cord from the laptop.
  2. Dell Inspiron 1564 Laptop Battery Replacement: paso 2, imagen 1 de 1
    • Turn the laptop off by holding down the silver power button in the upper left corner until all the lights turn off.
    • If the laptop is not turned off, there is a risk of electrical shock when replacing the battery.
  3. Dell Inspiron 1564 Laptop Battery Replacement: paso 3, imagen 1 de 1
    • Close the cover of the laptop and turn the laptop over so the the bottom is facing up.
    • Locate the release latch.
    • Locate the battery on the bottom of the laptop.
  4. Dell Inspiron 1564 Laptop Battery Replacement: paso 4, imagen 1 de 1
    • Slide the battery release latch to the right and hold it.
    • With your other hand, pull the battery away from the laptop and release the latch.
    • Discard the old battery according to your local laws.
Conclusión
- A new Dell Inspiron 1564 battery can be bought at www.laptopbatteryhq.com for about $30
6 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 23
Todo El Tiempo: 13,246
