Saltar al contenido principal
Introducción
In this guide, we will be showing you how to remove and replace the Memory Module.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
  1. Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  2. Align the notch in the NEW memory module with the tab in the memory module connector. Align the notch in the NEW memory module with the tab in the memory module connector.
    • Align the notch in the NEW memory module with the tab in the memory module connector.
  3. Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Linea de Meta
Terrence15
Miembro Desde 18/12/17
70,933 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
930 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 13
