Saltar al contenido principal
Dell Inspiron 1545 CPU Heat Sink Replacement
Qué necesitas
  1. Dell Inspiron 1545 CPU Heat Sink Replacement, Battery: paso 1, imagen 1 de 1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 CPU Heat Sink Replacement: paso 2, imagen 1 de 1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 CPU Heat Sink Replacement: paso 3, imagen 1 de 1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 CPU Heat Sink Replacement, Base Cover: paso 4, imagen 1 de 1
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  5. Dell Inspiron 1545 CPU Heat Sink Replacement: paso 5, imagen 1 de 2 Dell Inspiron 1545 CPU Heat Sink Replacement: paso 5, imagen 2 de 2
    • Carefully lift the base cover vertically away from the laptop.
  6. Dell Inspiron 1545 CPU Heat Sink Replacement, CPU Heat Sink: paso 6, imagen 1 de 1
    • Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
    • These screws are held in place by a washer so you should not be able to completely remove the screws.
  7. Dell Inspiron 1545 CPU Heat Sink Replacement: paso 7, imagen 1 de 1
    • Pull up on the Heat Sink unit to remove it.
Conclusión
6 personas más completaron esta guía.
Nathan Lemay
Miembro Desde 04/16/14
3,064 Reputación
15 Guías creadas
Equipo
Cal Poly, Team 9-14, Regan Spring 2014 Miembro de Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 23
Todo El Tiempo: 2,067
