Saltar al contenido principal
Dell Inspiron 1526 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 1526 Keyboard Replacement, Battery: paso 1, imagen 1 de 3 Dell Inspiron 1526 Keyboard Replacement, Battery: paso 1, imagen 2 de 3 Dell Inspiron 1526 Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • Slide the unlock button to the left to release the battery.
    • Slide the battery away from the laptop to remove.
    • The unlock button is located on the bottom of the laptop.
  2. Dell Inspiron 1526 Keyboard Replacement, Keyboard: paso 2, imagen 1 de 1
    • Loosen the two 3.5mm Phillips #1 screws in the battery bay.
  3. Dell Inspiron 1526 Keyboard Replacement: paso 3, imagen 1 de 1
    • Flip the laptop over.
    • Lift the control cover by prying the right side of the cover with an iFixit opening tool.
  4. Dell Inspiron 1526 Keyboard Replacement: paso 4, imagen 1 de 1
    • Carefully lift the control cover up and forward to reveal a single ribbon cable.
  5. Dell Inspiron 1526 Keyboard Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to squeeze the tabs on the connector and remove the ribbon cable.
  6. Dell Inspiron 1526 Keyboard Replacement: paso 6, imagen 1 de 2 Dell Inspiron 1526 Keyboard Replacement: paso 6, imagen 2 de 2
    • Remove the control cover.
  7. Dell Inspiron 1526 Keyboard Replacement: paso 7, imagen 1 de 1
    • Remove the two 3mm Phillips #1 screws at the top of the keyboard where the control cover was.
  8. Dell Inspiron 1526 Keyboard Replacement: paso 8, imagen 1 de 1
    • Lift the keyboard gently from the top, but do not remove completely.
    • Looking under the keyboard, towards the touch-pad in the center, lift up the black tab on the connector with tweezers for the keyboard ribbon cable.
  9. Dell Inspiron 1526 Keyboard Replacement: paso 9, imagen 1 de 2 Dell Inspiron 1526 Keyboard Replacement: paso 9, imagen 2 de 2
    • Remove the keyboard.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 131
