Saltar al contenido principal
Introducción
In this guide, we will be showing you how to remove and replace the Hard Drive.
Partes
No se especificaron partes.
  1. Follow the procedures in Before You Begin.
    • Follow the procedures in Before You Begin.
    • Turn the computer over and remove the two hard drive screws.
  2. Slide the hard drive out of the computer.
    • Slide the hard drive out of the computer.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Remove the two screws (one from each side of the hard drive cover), then pull to separate the cover from the hard drive. Remove the two screws (one from each side of the hard drive cover), then pull to separate the cover from the hard drive.
    • Remove the two screws (one from each side of the hard drive cover), then pull to separate the cover from the hard drive.
  5. Replace the hard drive cover and tighten the two screws to secure the cover to the NEW hard drive. Replace the hard drive cover and tighten the two screws to secure the cover to the NEW hard drive.
    • Replace the hard drive cover and tighten the two screws to secure the cover to the NEW hard drive.
  6. NOTICE: Use firm and even pressure to slide the hard drive into place. Excessive force may result in damage to the connector.
    • NOTICE: Use firm and even pressure to slide the hard drive into place. Excessive force may result in damage to the connector.
    • Slide the hard drive into the hard drive bay until the drive is fully seated.
  7. Replace the two screws to secure the hard drive.
    • Replace the two screws to secure the hard drive.
Linea de Meta
Terrence15
Miembro Desde 18/12/17
70,785 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 15
