Saltar al contenido principal
Dell Inspiron 1525 Wireless Mini-Card Replacement
Qué necesitas
  1. Dell Inspiron 1525 Wireless Mini-Card Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Wireless Mini-Card Replacement: paso 2, imagen 1 de 2 Dell Inspiron 1525 Wireless Mini-Card Replacement: paso 2, imagen 2 de 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Wireless Mini-Card Replacement, Bottom Cover: paso 3, imagen 1 de 2 Dell Inspiron 1525 Wireless Mini-Card Replacement, Bottom Cover: paso 3, imagen 2 de 2
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  4. Dell Inspiron 1525 Wireless Mini-Card Replacement, Wireless Mini-Card: paso 4, imagen 1 de 2 Dell Inspiron 1525 Wireless Mini-Card Replacement, Wireless Mini-Card: paso 4, imagen 2 de 2
    • Use the flat end of a spudger to gently pry the black and white antenna connectors off the Wireless Mini-Card.
  5. Dell Inspiron 1525 Wireless Mini-Card Replacement: paso 5, imagen 1 de 2 Dell Inspiron 1525 Wireless Mini-Card Replacement: paso 5, imagen 2 de 2
    • Remove the 3.70 mm Phillips #1 screw securing the card to the laptop.
    • The card will tilt up when you remove the screw.
    • Slide the card straight out.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 8,864
