Saltar al contenido principal
Dell Inspiron 1525 RAM Replacement
Qué necesitas
  1. Dell Inspiron 1525 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 RAM Replacement: paso 2, imagen 1 de 2 Dell Inspiron 1525 RAM Replacement: paso 2, imagen 2 de 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 RAM Replacement, Bottom Cover: paso 3, imagen 1 de 2 Dell Inspiron 1525 RAM Replacement, Bottom Cover: paso 3, imagen 2 de 2
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  4. Dell Inspiron 1525 RAM Replacement, RAM: paso 4, imagen 1 de 3 Dell Inspiron 1525 RAM Replacement, RAM: paso 4, imagen 2 de 3 Dell Inspiron 1525 RAM Replacement, RAM: paso 4, imagen 3 de 3
    • Push the white tabs on either side of the RAM chip outward. The chip should pop up a little.
    • Carefully remove the RAM chip by pulling it out at a slight vertical angle.
  5. Dell Inspiron 1525 RAM Replacement: paso 5, imagen 1 de 2 Dell Inspiron 1525 RAM Replacement: paso 5, imagen 2 de 2
    • Remove the lower RAM chip in the same fashion as the upper one.
Conclusión
5 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 10,824
