Saltar al contenido principal
Dell Inspiron 1525 Hard Drive Tray Replacement
Qué necesitas
  1. Dell Inspiron 1525 Hard Drive Tray Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Hard Drive Tray Replacement: paso 2, imagen 1 de 2 Dell Inspiron 1525 Hard Drive Tray Replacement: paso 2, imagen 2 de 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Hard Drive Tray Replacement, Hard Drive: paso 3, imagen 1 de 3 Dell Inspiron 1525 Hard Drive Tray Replacement, Hard Drive: paso 3, imagen 2 de 3 Dell Inspiron 1525 Hard Drive Tray Replacement, Hard Drive: paso 3, imagen 3 de 3
    • Remove the two 3.60 mm #1 Phillips screws securing the hard drive and hard drive tray.
    • Slide the hard drive and hard drive tray out of the laptop.
  4. Dell Inspiron 1525 Hard Drive Tray Replacement, Hard Drive Tray: paso 4, imagen 1 de 2 Dell Inspiron 1525 Hard Drive Tray Replacement, Hard Drive Tray: paso 4, imagen 2 de 2
    • Remove the two 3.55 mm Phillips #1 screws securing the hard drive to the hard drive tray.
    • There is 1 screw on each side of the tray.
    • Remove the hard drive from the tray.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 3,353
