Saltar al contenido principal
Dell Inspiron 1521 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 1521 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Rotate the laptop so its bottom is facing up.
  2. Dell Inspiron 1521 Keyboard Replacement: paso 2, imagen 1 de 3 Dell Inspiron 1521 Keyboard Replacement: paso 2, imagen 2 de 3 Dell Inspiron 1521 Keyboard Replacement: paso 2, imagen 3 de 3
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  3. Dell Inspiron 1521 Keyboard Replacement, Keyboard: paso 3, imagen 1 de 3 Dell Inspiron 1521 Keyboard Replacement, Keyboard: paso 3, imagen 2 de 3 Dell Inspiron 1521 Keyboard Replacement, Keyboard: paso 3, imagen 3 de 3
    • Find the two small indentations of the sides of the panel covering the power button.
    • Pry up both sides of the panel by sticking the plastic opener tool in each indentation and prying up.
  4. Dell Inspiron 1521 Keyboard Replacement: paso 4, imagen 1 de 1
    • Now that the panel is loose simply pull the panel off with your hand.
  5. Dell Inspiron 1521 Keyboard Replacement: paso 5, imagen 1 de 3 Dell Inspiron 1521 Keyboard Replacement: paso 5, imagen 2 de 3 Dell Inspiron 1521 Keyboard Replacement: paso 5, imagen 3 de 3
    • Locate the two 5 mm Phillips #1 screws holding down the keyboard that were underneath the panel.
    • Remove these screws with a Phillips #1 screwdriver.
    • With the screws removed pull the keyboard up with your hand.
  6. Dell Inspiron 1521 Keyboard Replacement: paso 6, imagen 1 de 3 Dell Inspiron 1521 Keyboard Replacement: paso 6, imagen 2 de 3 Dell Inspiron 1521 Keyboard Replacement: paso 6, imagen 3 de 3
    • Locate the connector that links the keyboard to the laptop.
    • Gently pull the connector toward the screen of the laptop with your figers to disconnect it.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 15-47, Forte Fall 2012 Miembro de Cal Poly, Team 15-47, Forte Fall 2012
CPSU-FORTE-F12S15G47
5 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 2,079
