Introducción
This guide will explain to you how to remove and replace the "lid" of the laptop, which contains the liquid crystal display (LCD screen).
Qué necesitas
Find the two small indentations of the sides of the panel covering the power button.
Pry up both sides of the panel by sticking the plastic opener tool in each indentation and prying up.
Locate the two Phillips #1 screws holding the Wireless Local Area Network (WLAN) panel in place.
Remove these two screws with a Phillips #1 screwdriver.
Remove the WLAN panel by pulling it up with your hand.
Remove the two 10 mm Phillips #1 screws from the bottom of the laptop that attach the lid assembly to the laptop with a Phillips #1 screwdriver.
Remove the two 10 mm Phillips #1 screws from the back of the laptop that also attach the lid assembly to the laptop with a Phillips #1 screwdriver.
