Saltar al contenido principal
Introducción
In this guide, we will be showing you how to remove and replace the Display Assembly.
Partes
No se especificaron partes.
    • Follow the instructions in Before You Begin.
    • Close the display and turn the computer over.
  1. Loosen the two captive screws that secure the Mini Card compartment cover, then remove the cover and set it aside. Loosen the two captive screws that secure the Mini Card compartment cover, then remove the cover and set it aside.
    • Loosen the two captive screws that secure the Mini Card compartment cover, then remove the cover and set it aside.
  2. Remove the two M2.5 x 8-mm screws from the bottom of the computer. Remove the two M2.5 x 8-mm screws from the bottom of the computer.
    • Remove the two M2.5 x 8-mm screws from the bottom of the computer.
  3. Remove the two M2.5 x 8-mm screws from the back of the computer.
    • Remove the two M2.5 x 8-mm screws from the back of the computer.
  4. Loosen the captive grounding screw, then disconnect the display cable from the display cable connector on the system board.
    • Loosen the captive grounding screw, then disconnect the display cable from the display cable connector on the system board.
  5. Disconnect the camera/microphone cable from the camera/microphone cable connector on the system board.
    • Disconnect the camera/microphone cable from the camera/microphone cable connector on the system board.
  6. Kits de reparación de iPhone X
    ¿Garantía vencida? No te preocupes, tenemos la solución.
    Comprar Ahora
    Comprar Ahora
  7. Lift the display cable and antenna cables from beneath the tabs on the palm rest. NOTICE: Ensure that the display cable and the antenna cables do not get caught beneath the plastic tabs on the palm rest.
    • Lift the display cable and antenna cables from beneath the tabs on the palm rest.
    • NOTICE: Ensure that the display cable and the antenna cables do not get caught beneath the plastic tabs on the palm rest.
  8. Lift the display assembly out of the computer.
    • Lift the display assembly out of the computer.
    • Align the display hinges with the holes in the base of the computer, then lower the display into place.
  9. Slide the antenna cables through the hole in the palm rest and the base of the computer.
    • Slide the antenna cables through the hole in the palm rest and the base of the computer.
    • NOTICE: Ensure that the display cable and antenna cables are properly routed and secured beneath the plastic tabs on the palm rest.
  10. Route the display cable and antenna cables beneath the plastic tabs on the palm rest.
    • Route the display cable and antenna cables beneath the plastic tabs on the palm rest.
  11. Connect the camera/microphone cable to the camera/microphone cable connector on the system board.
    • Connect the camera/microphone cable to the camera/microphone cable connector on the system board.
  12. Connect the display cable to the display cable connector on the system board.
    • Connect the display cable to the display cable connector on the system board.
  13. Replace and tighten the captive grounding screw.
    • Replace and tighten the captive grounding screw.
  14. Replace the two M2.5 x 8-mm screws on the back of the computer.
    • Replace the two M2.5 x 8-mm screws on the back of the computer.
  15. Replace the two M2.5 x 8-mm screws on the bottom of the computer. Replace the two M2.5 x 8-mm screws on the bottom of the computer.
    • Replace the two M2.5 x 8-mm screws on the bottom of the computer.
    • Replace the Mini Card compartment cover and tighten the screws.
Linea de Meta
Terrence15
Miembro Desde 18/12/17
71,146 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
930 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 8
Todo El Tiempo: 61
