Saltar al contenido principal
Dell Inspiron 1501 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 1501 Keyboard Replacement, Battery: paso 1, imagen 1 de 3 Dell Inspiron 1501 Keyboard Replacement, Battery: paso 1, imagen 2 de 3 Dell Inspiron 1501 Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • Place the laptop facedown with the battery facing you.
    • Push the switch above the battery to the right and hold it in that position.
    • Lift the battery using the grip on the top and remove it from its socket.
  2. Dell Inspiron 1501 Keyboard Replacement, Hinge Cover: paso 2, imagen 1 de 2 Dell Inspiron 1501 Keyboard Replacement, Hinge Cover: paso 2, imagen 2 de 2
    • Open the laptop all the way, rotating the display so that it is level with the surface that you are working on.
    • Insert the spudger underneath the groove on the right side of the hinge cover.
    • Push up to pry the edge of the hinge cover out.
    • Lift up to release the hinge cover from the laptop, working from right to left.
  3. Dell Inspiron 1501 Keyboard Replacement, Keyboard: paso 3, imagen 1 de 3 Dell Inspiron 1501 Keyboard Replacement, Keyboard: paso 3, imagen 2 de 3 Dell Inspiron 1501 Keyboard Replacement, Keyboard: paso 3, imagen 3 de 3
    • Remove the two 5mm JIS #1 screws from the top of the keyboard.
    • Lift the top of the keyboard up and pull the keyboard away from the laptop.
    • Be sure not to break the ribbon connector that attaches the keyboard to the laptop.
  4. Dell Inspiron 1501 Keyboard Replacement: paso 4, imagen 1 de 2 Dell Inspiron 1501 Keyboard Replacement: paso 4, imagen 2 de 2
    • Open the latch holding the ribbon from the top
    • Remove the keyboard from the laptop.
Conclusión
2 personas más completaron esta guía.
Don Dao
Miembro Desde 03/01/18
361 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 667
