Saltar al contenido principal
Dell Inspiron 15-7567 Wireless Card Replacement
Qué necesitas
  1. Dell Inspiron 15-7567 Wireless Card  Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off laptop before beginning.
    • Place the laptop upside down on a flat, stable surface.
  2. Dell Inspiron 15-7567 Wireless Card  Replacement: paso 2, imagen 1 de 2 Dell Inspiron 15-7567 Wireless Card  Replacement: paso 2, imagen 2 de 2
    • Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver.
  3. Dell Inspiron 15-7567 Wireless Card  Replacement: paso 3, imagen 1 de 1
    • Remove the panel from the sides and pull it out at an angle towards you.
  4. Dell Inspiron 15-7567 Wireless Card  Replacement: paso 4, imagen 1 de 2 Dell Inspiron 15-7567 Wireless Card  Replacement: paso 4, imagen 2 de 2
    • Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
  5. Dell Inspiron 15-7567 Wireless Card  Replacement: paso 5, imagen 1 de 2 Dell Inspiron 15-7567 Wireless Card  Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
    • Pinch the clips on the left and right side while pulling on the cord at the same time.
  6. Dell Inspiron 15-7567 Wireless Card  Replacement: paso 6, imagen 1 de 1
    • Pull the battery towards you.
    • Make sure to pull at an upward angle.
  7. Dell Inspiron 15-7567 Wireless Card  Replacement, Wireless Card: paso 7, imagen 1 de 2 Dell Inspiron 15-7567 Wireless Card  Replacement, Wireless Card: paso 7, imagen 2 de 2
    • Remove the 3mm screw using the Phillips #0 screwdriver in the location shown.
    • Remove the grey panel as well.
  8. Dell Inspiron 15-7567 Wireless Card  Replacement: paso 8, imagen 1 de 1
    • Detach the black and white wires connected to the card by gently lifting up on the wires.
  9. Dell Inspiron 15-7567 Wireless Card  Replacement: paso 9, imagen 1 de 2 Dell Inspiron 15-7567 Wireless Card  Replacement: paso 9, imagen 2 de 2
    • Gently pull the wireless card out at an angle towards you.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 799
