Introducción
This guide can teach you how to repair and replace the cooling fan on the Dell Inspiron 15-7560 laptop.
Herramientas
Partes
No se especificaron partes.
Step 1. Open the computer protective case.
First power off the laptop and turn the back of the computer up and you will find there are 11 approximately 5mm phillips screws.
Use a screwdriver to unscrew the screws on the back of the computer and open the back of the computer. Because the back shell of the Dell computer has a lock design, the three screws below cannot be unscrewed, as long as the screws are screwed to the maximum and slip with some sliding sound.
Step 3. Remove the wires from the fan connection.
You will find that there are wires connected to the fan.
First tear off the black insulating tape and then find the white sawtooth-like interface and pinch the two sides with your thumb and index fingernail and pull it apart. This way we have successfully removed the broken fan.
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
44%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
