Saltar al contenido principal
Dell Inspiron 15-7559 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 3 Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: paso 1, imagen 2 de 3 Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: paso 1, imagen 3 de 3
    • Using the flat end of the spudger press in the 5 tabs, located on top of the keyboard, as you use the spudger to pry each section up.
    • After releasing the 5 tabs, slide the opening tool around the top and sides of the keyboard to make sure it is fully released.
  2. Dell Inspiron 15-7559 Keyboard Replacement: paso 2, imagen 1 de 2 Dell Inspiron 15-7559 Keyboard Replacement: paso 2, imagen 2 de 2
    • Now lift the keyboard enough to access the ribbon cables beneath it.
  3. Dell Inspiron 15-7559 Keyboard Replacement: paso 3, imagen 1 de 3 Dell Inspiron 15-7559 Keyboard Replacement: paso 3, imagen 2 de 3 Dell Inspiron 15-7559 Keyboard Replacement: paso 3, imagen 3 de 3
    • For the two ribbon cables connecting the keyboard to the laptop, use your finger to lift the latch up.
    • Once the latch is raised, lift the ribbon cable up and out of the latch.
  4. Dell Inspiron 15-7559 Keyboard Replacement: paso 4, imagen 1 de 1
    • Now that the keyboard has been fully disconnected from the laptop, lift it off of the device.
Conclusión
8 personas más completaron esta guía.
Equipo
UW Tacoma, Team S3-G2, Liner Fall 2017 Miembro de UW Tacoma, Team S3-G2, Liner Fall 2017
UWT-LINER-F17S3G2
5 Miembros
9 Guías creadas
2 comentarios
How to put it back
Using Name - Contestar
Do the steps in reverse order, like it says at the end of the tutorial
Arthur Alford -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 37
Todo El Tiempo: 6,831
