Saltar al contenido principal
Dell Inspiron 15-7548 Motherboard Replacement
Qué necesitas
  1. Dell Inspiron 15-7548 Motherboard Replacement, Back Panel: paso 1, imagen 1 de 2 Dell Inspiron 15-7548 Motherboard Replacement, Back Panel: paso 1, imagen 2 de 2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 Motherboard Replacement: paso 2, imagen 1 de 2 Dell Inspiron 15-7548 Motherboard Replacement: paso 2, imagen 2 de 2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548 Motherboard Replacement, Motherboard: paso 3, imagen 1 de 1
    • Remove the screws holding the battery.
  4. Dell Inspiron 15-7548 Motherboard Replacement: paso 4, imagen 1 de 1
    • Disconnect the battery ribbon connector.
  5. Dell Inspiron 15-7548 Motherboard Replacement: paso 5, imagen 1 de 1
    • Disconnect the CPU fan ribbon.
  6. Dell Inspiron 15-7548 Motherboard Replacement: paso 6, imagen 1 de 1
    • Disconnect the display screen ribbon connector.
  7. Dell Inspiron 15-7548 Motherboard Replacement: paso 7, imagen 1 de 1
    • Disconnect the blue ribbon connector.
  8. Dell Inspiron 15-7548 Motherboard Replacement: paso 8, imagen 1 de 1
    • Disconnect the blue and gold ribbon connectors.
  9. Dell Inspiron 15-7548 Motherboard Replacement: paso 9, imagen 1 de 1
    • Disconnect the speaker cable.
  10. Dell Inspiron 15-7548 Motherboard Replacement: paso 10, imagen 1 de 1
    • Disconnect the WiFi card connections.
  11. Dell Inspiron 15-7548 Motherboard Replacement: paso 11, imagen 1 de 1
    • Remove the screws securing the heat sink.
  12. Dell Inspiron 15-7548 Motherboard Replacement: paso 12, imagen 1 de 1
    • Remove the heat sink.
  13. Dell Inspiron 15-7548 Motherboard Replacement: paso 13, imagen 1 de 1
    • Remove the motherboard screws.
  14. Dell Inspiron 15-7548 Motherboard Replacement: paso 14, imagen 1 de 1
    • Remove the motherboard.
Conclusión
Michael Nunez
Miembro Desde 04/12/22
325 Reputación
2 Guías creadas
Equipo
IUPUI, Team 3-3, Beck Spring 2022 Miembro de IUPUI, Team 3-3, Beck Spring 2022
IUPUI-BECK-S22S3G3
4 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 541
