Saltar al contenido principal
Dell Inspiron 15-7548 Fan Replacement
Qué necesitas
  1. Dell Inspiron 15-7548 Fan Replacement, Back Panel: paso 1, imagen 1 de 2 Dell Inspiron 15-7548 Fan Replacement, Back Panel: paso 1, imagen 2 de 2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 Fan Replacement: paso 2, imagen 1 de 2 Dell Inspiron 15-7548 Fan Replacement: paso 2, imagen 2 de 2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548 Fan Replacement, Battery: paso 3, imagen 1 de 2 Dell Inspiron 15-7548 Fan Replacement, Battery: paso 3, imagen 2 de 2
    • Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
  4. Dell Inspiron 15-7548 Fan Replacement: paso 4, imagen 1 de 2 Dell Inspiron 15-7548 Fan Replacement: paso 4, imagen 2 de 2
    • Remove the four 2.5x6mm screws using a Phillips #1 screwdriver.
  5. Dell Inspiron 15-7548 Fan Replacement, Fan: paso 5, imagen 1 de 1
    • The two fans are located at the top of the computer.
    • The fan on the left is for the GPU (Graphics processing unit) and the right fan is for the CPU (Central processing unit).
  6. Dell Inspiron 15-7548 Fan Replacement: paso 6, imagen 1 de 3 Dell Inspiron 15-7548 Fan Replacement: paso 6, imagen 2 de 3 Dell Inspiron 15-7548 Fan Replacement: paso 6, imagen 3 de 3
    • To unplug the CPU fan lift the black plastic cutout next to the fan.
    • The connection can be removed by hand or with the plastic spudger.
  7. Dell Inspiron 15-7548 Fan Replacement: paso 7, imagen 1 de 2 Dell Inspiron 15-7548 Fan Replacement: paso 7, imagen 2 de 2
    • Remove the two 2x3mm screws from the fan using the Phillips #1 screwdriver.
    • The unit may now be removed from the board.
    • The black cord running alongside the fan is for the display. Push it aside if it stops you from removing the fan.
  8. Dell Inspiron 15-7548 Fan Replacement: paso 8, imagen 1 de 3 Dell Inspiron 15-7548 Fan Replacement: paso 8, imagen 2 de 3 Dell Inspiron 15-7548 Fan Replacement: paso 8, imagen 3 de 3
    • Disconnect the unit from the motherboard.
    • It may be easier to disconnect with the spudger tool but it can also be done by hand.
  9. Dell Inspiron 15-7548 Fan Replacement: paso 9, imagen 1 de 2 Dell Inspiron 15-7548 Fan Replacement: paso 9, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • The black and white wires need to be unplugged and removed from the tabs on the fan.
    • Use a pair of tweezers to unplug the wires.
    • When reconnecting the wires connect the white to the top plug and the black to the bottom.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 23
Todo El Tiempo: 2,571
