Saltar al contenido principal
Dell Inspiron 15-7547 RAM Replacement
Qué necesitas
  1. Dell Inspiron 15-7547 RAM Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 RAM Replacement: paso 2, imagen 1 de 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 RAM Replacement, RAM: paso 3, imagen 1 de 3 Dell Inspiron 15-7547 RAM Replacement, RAM: paso 3, imagen 2 de 3 Dell Inspiron 15-7547 RAM Replacement, RAM: paso 3, imagen 3 de 3
    • Remove the plastic heat spreader that covers the RAM sticks.
  4. Dell Inspiron 15-7547 RAM Replacement: paso 4, imagen 1 de 2 Dell Inspiron 15-7547 RAM Replacement: paso 4, imagen 2 de 2
    • Release the clamps on each side of the RAM sticks by pushing away from the center.
    • When done properly the RAM stick should pop up.
  5. Dell Inspiron 15-7547 RAM Replacement: paso 5, imagen 1 de 2 Dell Inspiron 15-7547 RAM Replacement: paso 5, imagen 2 de 2
    • Pull the RAM stick in a straight line out of the socket.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 307
