Saltar al contenido principal
Dell Inspiron 15-7547 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 15-7547 Keyboard Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Keyboard Replacement: paso 2, imagen 1 de 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Keyboard Replacement, Battery: paso 3, imagen 1 de 2 Dell Inspiron 15-7547 Keyboard Replacement, Battery: paso 3, imagen 2 de 2
    • Remove the five 5.0 mm-long Philips #0 screws that connect the battery to the case.
  4. Dell Inspiron 15-7547 Keyboard Replacement: paso 4, imagen 1 de 2 Dell Inspiron 15-7547 Keyboard Replacement: paso 4, imagen 2 de 2
    • Lift the battery out of the case.
  5. Dell Inspiron 15-7547 Keyboard Replacement: paso 5, imagen 1 de 3 Dell Inspiron 15-7547 Keyboard Replacement: paso 5, imagen 2 de 3 Dell Inspiron 15-7547 Keyboard Replacement: paso 5, imagen 3 de 3
    • Pull the battery cable's pull tab towards the battery to disconnect it from the motherboard.
    • Pull parallel to the motherboard, not straight up.
    • Most of the cable is attached to the case with adhesive, which may cause slight resistance.
    • Remove the battery.
  6. Dell Inspiron 15-7547 Keyboard Replacement, Hard Drive: paso 6, imagen 1 de 2 Dell Inspiron 15-7547 Keyboard Replacement, Hard Drive: paso 6, imagen 2 de 2
    • Remove the four 5.0 mm-long Philips #0 screws connecting the hard drive to the chassis.
  7. Dell Inspiron 15-7547 Keyboard Replacement: paso 7, imagen 1 de 2 Dell Inspiron 15-7547 Keyboard Replacement: paso 7, imagen 2 de 2
    • Disconnect the hard drive from the motherboard by placing your fingers at the back, and pulling forward towards the front of the chassis.
  8. Dell Inspiron 15-7547 Keyboard Replacement: paso 8, imagen 1 de 1
    • Lift the hard drive out of the chassis.
  9. Dell Inspiron 15-7547 Keyboard Replacement, WiFi Card: paso 9, imagen 1 de 2 Dell Inspiron 15-7547 Keyboard Replacement, WiFi Card: paso 9, imagen 2 de 2
    • Remove the 3.0 mm-long Philips #0 screw at the end of the Wifi-Card
  10. Dell Inspiron 15-7547 Keyboard Replacement: paso 10, imagen 1 de 2 Dell Inspiron 15-7547 Keyboard Replacement: paso 10, imagen 2 de 2
    • Remove the Wifi-Card from its socket by pulling away and up from the connector.
  11. Dell Inspiron 15-7547 Keyboard Replacement: paso 11, imagen 1 de 2 Dell Inspiron 15-7547 Keyboard Replacement: paso 11, imagen 2 de 2
    • Disconnect the white and black cables from the Wifi-Card.
    • Make a note of which wire goes where for reconnecting them to the replacement card.
  12. Dell Inspiron 15-7547 Keyboard Replacement, Speakers: paso 12, imagen 1 de 3 Dell Inspiron 15-7547 Keyboard Replacement, Speakers: paso 12, imagen 2 de 3 Dell Inspiron 15-7547 Keyboard Replacement, Speakers: paso 12, imagen 3 de 3
    • Orient the computer so that the hinge for the display facing away from you.
    • Start removing the speaker on the left by pushing the speaker in the direction of the tick mark on the 2 outer pegs, then upwards
    • The tick marks on the two marked pegs should indicate the speaker needs to be pushed towards the center of the front of the chassis.
  13. Dell Inspiron 15-7547 Keyboard Replacement: paso 13, imagen 1 de 2 Dell Inspiron 15-7547 Keyboard Replacement: paso 13, imagen 2 de 2
    • Remove the left speaker by pushing the speaker in the direction of the tick mark on the center peg, then upwards
    • The tick mark should indicate towards the middle of the back of the chassis.
  14. Dell Inspiron 15-7547 Keyboard Replacement: paso 14, imagen 1 de 2 Dell Inspiron 15-7547 Keyboard Replacement: paso 14, imagen 2 de 2
    • Remove the wire connecting the left speaker to the right speaker.
    • The wire is secured by small notches, be careful not to break these.
  15. Dell Inspiron 15-7547 Keyboard Replacement: paso 15, imagen 1 de 2 Dell Inspiron 15-7547 Keyboard Replacement: paso 15, imagen 2 de 2
    • Start removing the right speaker by pushing the speaker in the direction of the tick marks on the 2 pegs closest to the front of the device, and then upwards.
    • These tick marks should indicate towards the middle of the back of the chassis.
  16. Dell Inspiron 15-7547 Keyboard Replacement: paso 16, imagen 1 de 1
    • Remove the right speaker by pushing in the direction of the tick mark on the final peg, and then upwards.
    • This tick mark should point towards the center of the right side of the chassis.
  17. Dell Inspiron 15-7547 Keyboard Replacement: paso 17, imagen 1 de 2 Dell Inspiron 15-7547 Keyboard Replacement: paso 17, imagen 2 de 2
    • Remove the cable connecting the right speaker to the motherboard by pulling towards the front of the device.
  18. Dell Inspiron 15-7547 Keyboard Replacement, CPU Fan: paso 18, imagen 1 de 2 Dell Inspiron 15-7547 Keyboard Replacement, CPU Fan: paso 18, imagen 2 de 2
    • Remove the two 5.0 mm-long Philips #0 screws from the fan.
    • The screw marked in orange will remain captive to the fan.
  19. Dell Inspiron 15-7547 Keyboard Replacement: paso 19, imagen 1 de 2 Dell Inspiron 15-7547 Keyboard Replacement: paso 19, imagen 2 de 2
    • Disconnect the wire that connects the fan to the motherboard. This can be found under the flap directly to the left of the fan.
  20. Dell Inspiron 15-7547 Keyboard Replacement: paso 20, imagen 1 de 1
    • Lift the fan out of the chassis.
  21. Dell Inspiron 15-7547 Keyboard Replacement, LCD Assembly: paso 21, imagen 1 de 3 Dell Inspiron 15-7547 Keyboard Replacement, LCD Assembly: paso 21, imagen 2 de 3 Dell Inspiron 15-7547 Keyboard Replacement, LCD Assembly: paso 21, imagen 3 de 3
    • Remove the six 7.0 mm-long Philips #0 screws that mount the hinges.
  22. Dell Inspiron 15-7547 Keyboard Replacement: paso 22, imagen 1 de 3 Dell Inspiron 15-7547 Keyboard Replacement: paso 22, imagen 2 de 3 Dell Inspiron 15-7547 Keyboard Replacement: paso 22, imagen 3 de 3
    • Use a spudger to unlatch and unplug the display cable.
    • There will be a notch on the side of the connector.
  23. Dell Inspiron 15-7547 Keyboard Replacement: paso 23, imagen 1 de 3 Dell Inspiron 15-7547 Keyboard Replacement: paso 23, imagen 2 de 3 Dell Inspiron 15-7547 Keyboard Replacement: paso 23, imagen 3 de 3
    • Raise the left and right hinges.
  24. Dell Inspiron 15-7547 Keyboard Replacement: paso 24, imagen 1 de 1
    • Remove the LCD display assembly from the laptop.
  25. Dell Inspiron 15-7547 Keyboard Replacement, Motherboard: paso 25, imagen 1 de 3 Dell Inspiron 15-7547 Keyboard Replacement, Motherboard: paso 25, imagen 2 de 3 Dell Inspiron 15-7547 Keyboard Replacement, Motherboard: paso 25, imagen 3 de 3
    • Unlatch the ribbon cable by pulling the white release up.
    • If this proves to be difficult using your fingers, try a plastic spudger.
    • Hold the blue flap and pull to unplug the cable.
  26. Dell Inspiron 15-7547 Keyboard Replacement: paso 26, imagen 1 de 3 Dell Inspiron 15-7547 Keyboard Replacement: paso 26, imagen 2 de 3 Dell Inspiron 15-7547 Keyboard Replacement: paso 26, imagen 3 de 3
    • Unlatch black release on the ribbon cable.
    • Hold the blue flap to unplug the cable.
  27. Dell Inspiron 15-7547 Keyboard Replacement: paso 27, imagen 1 de 3 Dell Inspiron 15-7547 Keyboard Replacement: paso 27, imagen 2 de 3 Dell Inspiron 15-7547 Keyboard Replacement: paso 27, imagen 3 de 3
    • Unlatch the ribbon cable by pulling the black release up.
    • Unlike the others, this release is found at the back.
    • Hold the flap and unplug the cable.
  28. Dell Inspiron 15-7547 Keyboard Replacement: paso 28, imagen 1 de 3 Dell Inspiron 15-7547 Keyboard Replacement: paso 28, imagen 2 de 3 Dell Inspiron 15-7547 Keyboard Replacement: paso 28, imagen 3 de 3
    • Unlike the others this release is found at back.
    • Hold the blue flap and unplug the cable.
  29. Dell Inspiron 15-7547 Keyboard Replacement: paso 29, imagen 1 de 3 Dell Inspiron 15-7547 Keyboard Replacement: paso 29, imagen 2 de 3 Dell Inspiron 15-7547 Keyboard Replacement: paso 29, imagen 3 de 3
    • Unplug the DC jack cable.
  30. Dell Inspiron 15-7547 Keyboard Replacement: paso 30, imagen 1 de 2 Dell Inspiron 15-7547 Keyboard Replacement: paso 30, imagen 2 de 2
    • Remove the seven 3.0 mm-long Philips #0 screws that secure the motherboard.
  31. Dell Inspiron 15-7547 Keyboard Replacement: paso 31, imagen 1 de 1
    • Remove the motherboard from the laptop.
  32. Dell Inspiron 15-7547 Keyboard Replacement, Keyboard: paso 32, imagen 1 de 2 Dell Inspiron 15-7547 Keyboard Replacement, Keyboard: paso 32, imagen 2 de 2
    • Remove the five 2.0 mm-long Philips #00 screws from the metal back-plate.
  33. Dell Inspiron 15-7547 Keyboard Replacement: paso 33, imagen 1 de 3 Dell Inspiron 15-7547 Keyboard Replacement: paso 33, imagen 2 de 3 Dell Inspiron 15-7547 Keyboard Replacement: paso 33, imagen 3 de 3
    • Peal away the two plastic covers marked GPU fan and CPU fan.
    • If never previously removed, these covers should be removed very gently so as to not tear the plastic underneath.
  34. Dell Inspiron 15-7547 Keyboard Replacement: paso 34, imagen 1 de 2 Dell Inspiron 15-7547 Keyboard Replacement: paso 34, imagen 2 de 2
    • Remove the twenty-two 2.0 mm-long Philips #00 screws that connect the keyboard to the chassis.
  35. Dell Inspiron 15-7547 Keyboard Replacement: paso 35, imagen 1 de 1
    • Lift the the keyboard from the chassis.
Conclusión
Una persona más ha completado esta guía.
Un comentario
I'm trying to source the 22 , 2.0 mm-long screws that connect the keyboard to the chassis but I dont know what the correct specifications to look for, can someone please help?
Marlon Fraser - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 38
Todo El Tiempo: 2,303
