Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Introducción
The CPU fan makes sure your CPU does not overheat. This guide shows the process of removing the CPU fan from the Dell Inspiron 15-7547.
Partes
No se especificaron partes.
  1. Close the display and flip the laptop on its back.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Pry the cover open with a plastic spudger   and remove it.
    • Pry the cover open with a plastic spudger and remove it.
  3. Remove the two 5.0 mm-long Philips #0 screws from the fan. The screw marked in orange will remain captive to the fan.
    • Remove the two 5.0 mm-long Philips #0 screws from the fan.
    • The screw marked in orange will remain captive to the fan.
  4. Disconnect the wire that connects the fan to the motherboard. This can be found under the flap directly to the left of the fan. Disconnect the wire that connects the fan to the motherboard. This can be found under the flap directly to the left of the fan.
    • Disconnect the wire that connects the fan to the motherboard. This can be found under the flap directly to the left of the fan.
  5. Lift the fan out of the chassis.
    • Lift the fan out of the chassis.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 160
