Saltar al contenido principal
Dell Inspiron 15-7547 Bottom Cover Replacement
Qué necesitas
  1. Dell Inspiron 15-7547 Bottom Cover Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Bottom Cover Replacement: paso 2, imagen 1 de 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 4,477
