Saltar al contenido principal
Dell Inspiron 15-7537 Wireless Card Replacement
Qué necesitas
  1. Dell Inspiron 15-7537 Wireless Card Replacement, Bottom Case: paso 1, imagen 1 de 1
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Wireless Card Replacement: paso 2, imagen 1 de 1
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Wireless Card Replacement: paso 3, imagen 1 de 1
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 Wireless Card Replacement, Remove the WiFi Card: paso 4, imagen 1 de 2 Dell Inspiron 15-7537 Wireless Card Replacement, Remove the WiFi Card: paso 4, imagen 2 de 2
    • Completely unscrew the 2 mm screw that connects the WiFi card to the mother board using a Philips head screwdriver.
  5. Dell Inspiron 15-7537 Wireless Card Replacement: paso 5, imagen 1 de 1
    • Disconnect the two antennas (one black and one white) from the wireless card.
  6. Dell Inspiron 15-7537 Wireless Card Replacement: paso 6, imagen 1 de 1
    • Remove the WiFi card.
    • To place a new WiFi card, connect the antenna cables to the WiFi card. The white cable goes to the white triangle, and the black cable goes to the black triangle.
    • Avoid damaging the card by not placing any cables underneath the card.
Linea de Meta
Una persona más ha completado esta guía.
Jean Whitmore
Miembro Desde 01/22/15
984 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 18-2, Maness Winter 2015 Miembro de Cal Poly, Team 18-2, Maness Winter 2015
CPSU-MANESS-W15S18G2
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 23
Todo El Tiempo: 3,635
