Introducción
Use this guide to replace your Dell Inspiron 15-7537 WiFi card if you have determined your WiFi connection issues are caused by a faulty WiFi card.
Qué necesitas
Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
Completely unscrew the 2 mm screw that connects the WiFi card to the mother board using a Philips head screwdriver.
Una persona más ha completado esta guía.
