Saltar al contenido principal
Dell Inspiron 15-7537 Battery Replacement
Qué necesitas
  1. Dell Inspiron 15-7537 Battery Replacement, Bottom Case: paso 1, imagen 1 de 1
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Battery Replacement: paso 2, imagen 1 de 1
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Battery Replacement: paso 3, imagen 1 de 1
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
  5. Dell Inspiron 15-7537 Battery Replacement: paso 5, imagen 1 de 1
    • Ground the system board by turning over the computer, opening the display, and holding the power button down for about 5 seconds before proceeding.
    • Using the pull tab on the battery, lift the battery out of the computer.
Conclusión
4 personas más completaron esta guía.
Abby Schmiedt
Miembro Desde 01/22/15
229 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 18-2, Maness Winter 2015 Miembro de Cal Poly, Team 18-2, Maness Winter 2015
CPSU-MANESS-W15S18G2
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 17
Ultimos 30 días: 35
Todo El Tiempo: 7,051
