Saltar al contenido principal
Introducción
In this guide, we will be showing you how to remove and replace the Hard Drive.
Partes
No se especificaron partes.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer. CAUTION: Hard drives are fragile. Exercise care when handling the hard drive. CAUTION: To avoid data loss, do not remove the hard drive while the computer is in sleep or on state.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in sleep or on state.
    • Lift the latch and using the pull tab, disconnect the hard-drive cable from the system board.
  2. Remove the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
    • Remove the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
  3. Lift the hard-drive assembly along with its cable off the palm rest and keyboard assembly.
    • Lift the hard-drive assembly along with its cable off the palm rest and keyboard assembly.
  4. Disconnect the interposer from the hard-drive assembly.
    • Disconnect the interposer from the hard-drive assembly.
  5. Kits de reparación de iPhone X
    ¿Garantía vencida? No te preocupes, tenemos la solución.
    Comprar Ahora
    Comprar Ahora
  6. Remove the screws that secure the hard-drive bracket to the hard drive.
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  7. Lift the hard drive off the hard-drive bracket. Lift the hard drive off the hard-drive bracket.
    • Lift the hard drive off the hard-drive bracket.
  8. Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  9. Replace the screws that secure the hard-drive bracket to the hard drive.
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  10. Connect the interposer to the hard-drive assembly.
    • Connect the interposer to the hard-drive assembly.
  11. Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly.
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly.
  12. Replace the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
    • Replace the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
  13. Connect the hard-drive cable to the system board and close the latch to secure the cable.
    • Connect the hard-drive cable to the system board and close the latch to secure the cable.
Linea de Meta
Terrence15
Miembro Desde 18/12/17
71,140 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
930 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 12
Últimos 30 Días: 81
Todo El Tiempo: 1,084
