Saltar al contenido principal
Dell Inspiron 15-5565 RAM Replacement
Qué necesitas
  1. Dell Inspiron 15-5565 RAM Replacement, Optical Drive: paso 1, imagen 1 de 1
    • Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
  2. Dell Inspiron 15-5565 RAM Replacement: paso 2, imagen 1 de 3 Dell Inspiron 15-5565 RAM Replacement: paso 2, imagen 2 de 3 Dell Inspiron 15-5565 RAM Replacement: paso 2, imagen 3 de 3
    • Eject the optical drive by pressing the eject button.
    • Push out the optical drive bracket using the iFixit opening tool.
  3. Dell Inspiron 15-5565 RAM Replacement, Back Cover: paso 3, imagen 1 de 2 Dell Inspiron 15-5565 RAM Replacement, Back Cover: paso 3, imagen 2 de 2
    • Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
  4. Dell Inspiron 15-5565 RAM Replacement: paso 4, imagen 1 de 2 Dell Inspiron 15-5565 RAM Replacement: paso 4, imagen 2 de 2
    • Remove the back cover from the laptop.
  5. Dell Inspiron 15-5565 RAM Replacement, RAM: paso 5, imagen 1 de 3 Dell Inspiron 15-5565 RAM Replacement, RAM: paso 5, imagen 2 de 3 Dell Inspiron 15-5565 RAM Replacement, RAM: paso 5, imagen 3 de 3
    • Use your fingers to pull the safety clips apart on either side of the memory module. This should make the module pop upwards.
    • Remove the module from its slot by pulling it out.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 21
Todo El Tiempo: 130
