Saltar al contenido principal
Dell Inspiron 15-5559 Hard Drive Replacement
Qué necesitas
  1. Dell Inspiron 15-5559 Hard Drive Replacement, Back Panel: paso 1, imagen 1 de 2 Dell Inspiron 15-5559 Hard Drive Replacement, Back Panel: paso 1, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the two 2.5x8mm screws on the back panel.
  2. Dell Inspiron 15-5559 Hard Drive Replacement: paso 2, imagen 1 de 2 Dell Inspiron 15-5559 Hard Drive Replacement: paso 2, imagen 2 de 2
    • Place the plastic spudger in the slot. Using the flat side of the spudger pry the back panel upward and off.
    • Do not be afraid to use a bit of muscle, as the panel does not come off without some force.
  3. Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 3 Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: paso 3, imagen 2 de 3 Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: paso 3, imagen 3 de 3
    • Remove each of the four (4) 2.5x8mm screws that anchor the hard drive using a Phillips #1 screwdriver.
  4. Dell Inspiron 15-5559 Hard Drive Replacement: paso 4, imagen 1 de 1
    • Use the plastic spudger to remove the hard drive conductive tape by lifting the black clasp holding it down, then pulling the conductive tape toward the left to remove it.
    • It does not take much force to remove the conductive tape. Remove it gently so that you do not damage it.
  5. Dell Inspiron 15-5559 Hard Drive Replacement: paso 5, imagen 1 de 2 Dell Inspiron 15-5559 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Place the plastic spudger underneath the hard drive at the indicated position.
    • Use the spudger along with your other hand to gently remove the hard drive.
Conclusión
4 personas más completaron esta guía.
Kyla Ward
Miembro Desde 03/19/18
580 Reputación
4 Guías creadas
Equipo
Baylor, Team S5-G5, Williams Spring 2018 Miembro de Baylor, Team S5-G5, Williams Spring 2018
BU-WILLIAMS-S18S5G5
3 Miembros
5 Guías creadas
2 comentarios
The blue part came off is that important?
walterandradeconde - Contestar
can i put this in a harddrive enclosure?
chiggly 123 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 23
Todo El Tiempo: 5,172
