Saltar al contenido principal
Dell Inspiron 15-5558 Screen Replacement
Qué necesitas
  1. Dell Inspiron 15-5558 Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 Screen Replacement: paso 2, imagen 1 de 1
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 Screen Replacement: paso 3, imagen 1 de 2 Dell Inspiron 15-5558 Screen Replacement: paso 3, imagen 2 de 2
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 Screen Replacement, Screen: paso 4, imagen 1 de 2 Dell Inspiron 15-5558 Screen Replacement, Screen: paso 4, imagen 2 de 2
    • Open device so it is at least opened at a 90 degree angle.
    • Wedge a spudger between the screen and the plastic frame.
    • Push in the spudger and push down to pop the frame from the pins.
    • Repeat around the whole frame.
  5. Dell Inspiron 15-5558 Screen Replacement: paso 5, imagen 1 de 3 Dell Inspiron 15-5558 Screen Replacement: paso 5, imagen 2 de 3 Dell Inspiron 15-5558 Screen Replacement: paso 5, imagen 3 de 3
    • Once all the pins are off, remove the frame by pulling it away from the screen.
    • Using a Phillips #0 screwdriver, unscrew the four 3mm screws holding the screen in place.
    • Push the spudger behind the screen and push down to remove the screen.
  6. Dell Inspiron 15-5558 Screen Replacement: paso 6, imagen 1 de 3 Dell Inspiron 15-5558 Screen Replacement: paso 6, imagen 2 de 3 Dell Inspiron 15-5558 Screen Replacement: paso 6, imagen 3 de 3
    • Pull the tape connecting the screen up with your fingers and pull the securing bar up with it.
    • Disconnect the securing bar to remove the screen.
Conclusión
7 personas más completaron esta guía.
Adam Lourenco
Miembro Desde 10/19/17
793 Reputación
5 Guías creadas
Equipo
3 comentarios
Where can I buy the screen from?
wardak_90 - Contestar
How many pins is the screen connector? 30? 40?
Adrian Lewis - Contestar
Very useful guide. Works with Dell Inspiron 15 5559. Screen replacement is a lot easier than replacing the whole screen assembly.
James Diamond - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 17
Ultimos 30 días: 24
Todo El Tiempo: 4,829
