Saltar al contenido principal
Dell Inspiron 15-5558 RAM Replacement
Qué necesitas
  1. Dell Inspiron 15-5558 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 RAM Replacement: paso 2, imagen 1 de 1
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 RAM Replacement: paso 3, imagen 1 de 2 Dell Inspiron 15-5558 RAM Replacement: paso 3, imagen 2 de 2
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 RAM Replacement, Hard Drive: paso 4, imagen 1 de 3 Dell Inspiron 15-5558 RAM Replacement, Hard Drive: paso 4, imagen 2 de 3 Dell Inspiron 15-5558 RAM Replacement, Hard Drive: paso 4, imagen 3 de 3
    • Using a Phillips #0 screwdriver, unscrew the two 8mm screws from the panel.
    • Take a spudger and wedge it between the panel and the base of the device.
    • Push down on the spudger until you hear a click sound.
    • Slide the spudger along the panel and continue to push down until the panel is completely detached.
    • Remove the panel.
  5. Dell Inspiron 15-5558 RAM Replacement: paso 5, imagen 1 de 3 Dell Inspiron 15-5558 RAM Replacement: paso 5, imagen 2 de 3 Dell Inspiron 15-5558 RAM Replacement: paso 5, imagen 3 de 3
    • Using the Phillips #0 screwdriver, remove the four 8mm screws holding down the hard drive.
    • Take the spudger and prop up the connector so it is no longer attached.
    • Use the spudger and prop up the hard drive and remove it.
  6. Dell Inspiron 15-5558 RAM Replacement, RAM: paso 6, imagen 1 de 3 Dell Inspiron 15-5558 RAM Replacement, RAM: paso 6, imagen 2 de 3 Dell Inspiron 15-5558 RAM Replacement, RAM: paso 6, imagen 3 de 3
    • Locate the two RAM cards.
    • Using your finger, pull the two small pins back from the RAM causing it to pop up.
  7. Dell Inspiron 15-5558 RAM Replacement: paso 7, imagen 1 de 1
    • Once popped up, pull the ram out.
Conclusión
Adam Lourenco
Miembro Desde 10/19/17
793 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 25
Ultimos 30 días: 38
Todo El Tiempo: 1,513
