Saltar al contenido principal
Dell Inspiron 15-5558 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 15-5558 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 Keyboard Replacement: paso 2, imagen 1 de 1
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 Keyboard Replacement: paso 3, imagen 1 de 2 Dell Inspiron 15-5558 Keyboard Replacement: paso 3, imagen 2 de 2
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 3 Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: paso 4, imagen 2 de 3 Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: paso 4, imagen 3 de 3
    • Identify the two small slots along the side of the keyboard closest to the screen.
    • Wedge the spudger in the two small slots and push the spudger in and down to detach the pins.
    • Using your hands, pull the keyboard up and out.
  5. Dell Inspiron 15-5558 Keyboard Replacement: paso 5, imagen 1 de 3 Dell Inspiron 15-5558 Keyboard Replacement: paso 5, imagen 2 de 3 Dell Inspiron 15-5558 Keyboard Replacement: paso 5, imagen 3 de 3
    • At the end of the ribbon cable attaching the keyboard to the device is a bar secure.
    • Using your finger or spudger, flip the bar up and the keyboard will be freed from the device.
Conclusión
5 personas más completaron esta guía.
Adam Lourenco
Miembro Desde 10/19/17
793 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 19
Todo El Tiempo: 1,934
