Saltar al contenido principal
Dell Inspiron 15-5552 CD-Drive Replacement
Qué necesitas
  1. Dell Inspiron 15-5552 CD-Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 CD-Drive Replacement: paso 2, imagen 1 de 1
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 CD-Drive Replacement: paso 3, imagen 1 de 1
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 CD-Drive Replacement: paso 4, imagen 1 de 2 Dell Inspiron 15-5552 CD-Drive Replacement: paso 4, imagen 2 de 2
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
  5. Dell Inspiron 15-5552 CD-Drive Replacement, Keyboard: paso 5, imagen 1 de 2 Dell Inspiron 15-5552 CD-Drive Replacement, Keyboard: paso 5, imagen 2 de 2
    • Keyboard
    • Insert a spudger next to the 5 plastic indents located at the top of the keyboard and gently pry to release the securing clips.
  6. Dell Inspiron 15-5552 CD-Drive Replacement: paso 6, imagen 1 de 2 Dell Inspiron 15-5552 CD-Drive Replacement: paso 6, imagen 2 de 2
    • Lift the keyboard off of the computer. *Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.*
  7. Dell Inspiron 15-5552 CD-Drive Replacement: paso 7, imagen 1 de 1
    • Flip the keyboard over onto the palm-rest assembly.
  8. Dell Inspiron 15-5552 CD-Drive Replacement: paso 8, imagen 1 de 2 Dell Inspiron 15-5552 CD-Drive Replacement: paso 8, imagen 2 de 2
    • Flip the black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
  9. Dell Inspiron 15-5552 CD-Drive Replacement, CD-Drive: paso 9, imagen 1 de 1
    • CD-Drive
    • Flip the computer over, *screen down* and unscrew the 1 screw in the middle located below the battery with a J0 bit tipped screwdriver.
  10. Dell Inspiron 15-5552 CD-Drive Replacement: paso 10, imagen 1 de 1
    • Next using the J0 bit tipped screwdriver unscrew the 2 remaining screws shown in the picture.
  11. Dell Inspiron 15-5552 CD-Drive Replacement: paso 11, imagen 1 de 2 Dell Inspiron 15-5552 CD-Drive Replacement: paso 11, imagen 2 de 2
    • After all 3 screws are removed take a spudger and pry the CD-Drive out of the computer.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 14
Ultimos 30 días: 15
Todo El Tiempo: 188
