Saltar al contenido principal
Dell Inspiron 15-5552 Battery Replacement
Qué necesitas
  1. Dell Inspiron 15-5552 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Battery Replacement: paso 2, imagen 1 de 1
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Battery Replacement: paso 3, imagen 1 de 1
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Battery Replacement: paso 4, imagen 1 de 2 Dell Inspiron 15-5552 Battery Replacement: paso 4, imagen 2 de 2
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 17
Ultimos 30 días: 17
Todo El Tiempo: 281
