Saltar al contenido principal
Dell Inspiron 15-5547 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 3 Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: paso 1, imagen 2 de 3 Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: paso 1, imagen 3 de 3
    • Use the Jimmy to pry and detach the keyboard from the laptop at the following locations.
    • Lift the keyboard from the top and gently detach it from the bottom end.
    • Be careful not to pull too quickly in order to avoid damage to the keyboard connector ribbon cables.
  2. Dell Inspiron 15-5547 Keyboard Replacement: paso 2, imagen 1 de 2 Dell Inspiron 15-5547 Keyboard Replacement: paso 2, imagen 2 de 2
    • Detach the smaller ribbon cable from the laptop connector base by gently pulling upward on the connector base. This will free the ribbon cable.
    • Detach the larger ribbon cable from the laptop connector base in the same manner as the first. This will completely detach the keyboard from the laptop.
    • Be careful when detaching and removing the ribbon cables so as not to tear or damage them.
Conclusión
4 personas más completaron esta guía.
Faiq Huzir
Miembro Desde 05/22/19
121 Reputación
1 Guía escrita
Equipo
IUPUI, Team S1-G3, Harley Summer 2019 Miembro de IUPUI, Team S1-G3, Harley Summer 2019
IUPUI-HARLEY-SU19S1G3
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 14
Todo El Tiempo: 869
